Bug with saving intensity presets (SOLVED)
Greetings! I noticed a bug with saving intensity effects in presets. I am doing a show coming up and I am having to use fixtures without a dedicated dimmer channel. The fixture uses the generic RGBAW+UV profile and I have virtual dimmer turned on. When I try to record an intensity effect as an intensity preset, the effect doesn’t save and only holds the base value. I made sure that I was recording all values and I tried to record without using any filters. I can record the intensity effects into chases and cuelists. It seems to be specifically related to intensity presets.
Edit: I reinstalled the software and it fixed the problem. Running Version: 4.0.10.10.0 (Release)
