Can't join show over WiFi
Hello, we have a problem to join a show if I try to connect with any devices over WiFi (the main PC is always connected over Ethernet), we can’t find the show. But if we connect the remote Client with ethernet, I can directly find the show.
So I tried to upgrade the main PC from XP to Win10 -> same result. Firewall is deactivated.
Can someone tell me what is the problem?
Hello @andreasoc!
So what you need to do is go to network settings. Then go to interfaces and select your wifi and enable X-Net.
If you dont follow i could send you pics of the menu.
Good luck!
//Martin Hedström
#3
Hey Martin,
that is not the problem. WiFi has the same setting like the ethernet card. :frowning:
#4
Do you have the IPv6 settings set on the wifi adapter where it is not active on the Ethernet adapter?
Maybe a solution will be to deactivate IPv6 and let only IPv4
On this link you will find how to deactivate IPv6 on your network adapter
https://medium.com/@JockDaRock/disabling-ipv6-on-network-adapter-windows-10-5fad010bca75
#5
IPv6!!! man thank you!
That solved the problem.
