Chase cannot run when Reset to First Cue isn't selected and Down Action is Toggle
as described in the Header, there is a problem when using chases on a playback button.
If you have a chase with:
  • some steps
  • “Reset to First Cue” is NOT SELECTED!
  • “Down Action” is “Toggle”
    Now after switching of the chase and switching on again by the playback button, the chase plays only the last active cue and than it stops at this cue. a more go command reactivates the chase. If the option “Reset to First Cue” is selected, it works as expected.
Best regards
Toby
