Common PC Installation Fixes
MSVCP140.dll not found
Download and install Microsoft package: https://www.microsoft.com/en-us/download/details.aspx?id=5555
Symptom:
Error 1720 “LoadDefaultShowFile script error” (Windows 10 only)
Cause:
COM+ Windows System is not running due to Realtek/Dolby sound driver startup issue.
This is a critical part of Windows that ONYX utilizes for real time synchronization across the software. The issue may be resolved by Dolby in a newer driver at some time. We created a workaround.
Confirm by launching “Component Services” from the Start Menu
Open Computers/My Computer. A Red Arrow will show next to the monitor icon.
Selecting COM+ Applications results in Error code 8004E00F
Fix :
Change the DOLBYDAXAPI service to delayed Start.
Apply this registry file to the PC and reboot.
FixCOM Dolby_Realtek.reg (590 Bytes)
Check the the COM+ system, no error should show.
Extra steps to check (and fix) are:
Install ONYX only if the COM+ error is solved.
#5
Fixing that underlying 8004E00F error is easier said than done.
I installed the registry tweak. No difference.
Lenovo X1 owners are experiencing the same problem but that’s due to a smart standby issue.
Both my systems that are failing do have Realtek HDA, but do not have the Dolby services installed. Delaying the startup of the realtek did not solve the issue. The two systems only have 2 things in common - the CPU manufacturer is AMD and they both have realtek HDA.
#6
I am afraid that with Windows, this issue for me is never going to be fixed. Does Elation have plans to remove the necessity for COM+ in the installer?
For me from a fresh 1803 install, Windows Automagically installed 21 drivers between when COM+ worked and when it didn’t. I don’t have the patience to disable them one at a time till I find it.
I know this is a big ask, but you would think a big version change would come with an updated installer. With Win 10, it’s increasingly more challenging to get a single installer to do everything. I have one program that requires me to install the pre requisites individually.
#7
I am having the same issue - 1720 error. Installing the registry tweak makes no difference. Running the Component Services after installing the tweak and rebooting till shows the 8004E00F error.
Running the Onyx install package after that still returns the 1720 error.
I’ve had two support phone calls and two email exchanges and this is the only solution I have been given - and it doesn’t work.
I’m installing on a brand new HP Envy with no other software installed (other than pre-installed). I’ve even wiped and reinstalled Windows twice to be sure there were no remnants of old installs.
Can someone please help? I’m ready to return the M-Play and M-DMX and go with another solution.
#8
I have the same problem with my HP Elitebook 840 G2 i7-5600U/16GB/512GB SSD. with a fresh Windows 10. couple of HP drivers for fingerprint, touchpad and networking.
#9
I also have this problem, i tried clean windows, with no luck
#10
For problems with HP computers, check this post, it saved me:
#11
Hello, could you please explain how to do it? I have this problem and I cannot Install or uninstall the previous install.
#12
You can use Onyx cleanup tool to uninstall.
https://obsidiancontrol.box.com/v/cleanup
#13
Hi, did you solved this issue by yourself?
You can disable this driver in services on windows. just right click the service --> properties --> dropdown menu --> set this to disabled --> apply and stop the service. then you need to restart your system.
I hope this quick explanation works :slight_smile:
