Hi all,
Whats the function of the encoder side bar on the right of the screen?
i can’t find it
Greetz Daan
Hi all,
i can’t find it
Greetz Daan
Tasz,
The Encoder Sidebar is another space to assign “direct access” or “quick control” of whatever attribute you choose to assign it. It corresponds to the physical encoders on the M2GO HD, M1 HD, M6, and NX 2 (Replacing the M2GoHD).
To active the sidebar, go to displays, find the display you want and enable that option. After it is enabled, you can use your mouse to right click the “virtual encoder” and choose the attribute you want.
Here is a link to turning the sidebar on.
http://support.obsidiancontrol.com/Content/Workspaces/Displays.htm
Here is a link to assigning an attribute (For an M6) but you’ll get the idea.
http://support.obsidiancontrol.com/Content/M-Series/M6/Encoder_Assignments.htm?Highlight=encoder
Thanx.
it is completely clear
Thank you so much for this. I was into this issue and tired to tinker around to check if its possible but couldnt get it done. Now that i have seen the way you did it, thanks guys
with
regards
