Fanning tool problem
Hi all,
I have some trouble with the fanning tool. When i use it, its do not respons ferry well.
When i fan the pan/tilt its works but fanning the intensity or order attribute i can only adjust the fan by 1% at the time.
Greetz Daan
Hi. You can also fan parameters via syntax
i.e.
select desired fixtures, @ 100 Thru 10 Thru 100, select Intensity output channel
Yes i know
But my point is that i have a problem with de fanning tool. So maybe its a bug.
Do have more people this problem with the fanning tool?
