Function assign on virtual buttons
If you assign a cue to a virtual playback button and then close the dialog window and assign another virtual playback button and then want to edit the first on in function ( e,g, from go to toggle) you cant enter the menu for function.
Watch this for the part starting around 00:44: https://www.youtube.com/watch?v=ivAd1erAUkE
Look at the popup at 00:53 in the video. If you click on the cog in that popup it will take you to the Cuelist Options window where you can change all the cuelist options (like from go to toggle).
If you aren’t displaying those actions on your virtual playback window, then you can instead:
  1. ‘Select’ the virtual playback that you want to update
  2. at the very top of the screen in the very center you should see the name of the cuelist that is assigned to that virtual playback
  3. click on that name at the top-center of the screen and you should get the same popup as seen in the video
  4. and again, click on the cog in that popup to get to the Cuelist Options window
