Global fade disable
is there an opportunity to enable or disable cuelist fade time global.
I have done my cuelists all with 1s fade time to have a smooth color crossover.
Sometimes in the show it would be nice if the color change snaps.
This could be done with a copied cuelist with fade time 0s but it is a little bit uncomftable to do every cue list two times.
Regards Mario
You can use the global fade speed from the rate of the encoders belts.
Up it to 1000% and you should have snap cuelits
#3
could it be assigned to a cuelist or playback to directly switch between 100% and 1000%.
Regards Mario
#4
No that’s not possible. I did not check about global fade speed, but for live time I know that following exists.
You can add in the side bar live time shortcut, so maybe there are global fade available?
