Since Win8 the help function doesn’t work. Anyone have access to help for LED trix? I’ve got the patch figured out but the colors I want aren’t cooperating, speed, all that.
what are you having problems with? I use LED trix all the time.
I’m not really. I just like to read the manual to see how things work.
Did you ever have someone reply with LJ TRIX help? I wanted to know where to find some assistance as well.
For LED Trix assistance, try searching the forums
New forum: http://controllerforum.elationlighting.com/
Old forum: http://forumarchive.martin.com/
I have found the links but can’t find any user manual or “how to get started” with TRIX.
Is the file you are looking for there?
https://martinprofessional.app.box.com/v/control/folder/1721411572
I have the LJ user manual but it doesn’t include anything for the LED TRIX plug in within LJ Manager. Do you have any forum link or other tutorials?
Hi Cody,
I’m wondering if you have some info to get me started on LED TRIX please? I have the LJ user manual but it doesn’t include anything for the LED TRIX plug in within LJ Manager. Do you have any forum link or other tutorials? Much appreciated.
hi, what effect are you trying to achieve? low res pattern sweeps, or capture window? also, where are you stuck?
have you considered switching to MPC, can easily accomplish all types of low res pattern sweeps and so on similar to pixel mapping minus capture and dedicated mapping engine. select pixel pattern, save as group, apply intensity fx and color fx engine, can even use built in color fx presets…then set wave offset
you will wonder why you waited this long between Youtube, Facebook user group, and here, you’ll be caught up in no time. glad to help if you have any questions
