LightJockey / ONYX Hardware Compatibility
Elation LightJockey Kit
Obsidian NX DMX
elation_professional_nx_dmx_nx_dmx_usb_powered_1544197822000_1442344
Martin M-DMX
USB Duo DMX
The above DMX hardware are for LJ 2.100 and above will only work with Lightjockey if this One-Key dongle is present
This hardware is Windows 7, 8.x, 10 (32/64 bit) compatible
The driver is automatically installed when installing Lightjockey or ONYX
Latest LightJockey 2 release download info (Windows 7 and Windows 8.x, 10 Compatible)
https://obsidiancontrol.box.com/lightjockey2
The above hardware’s also work with ONYX. with and without ONYX Key.
http://support.obsidiancontrol.com/Content/Onyx/Onyx_Licenses.htm
Elation Lighting does not offer support for any legacy Lightjockey hardware.
LightJockey 2.95.3 is only compatible with Windows XP and Vista.
Legacy Version 2.953
Legacy Hardware
90702055 LightJockey Universal DMX box
Discontinued: 2010
The driver is copied to the program folder when installing Lightjockey 2.9x
Example:
C:\Program Files (x86)\Martin Professional\Martin LightJockey\HardwareDrivers\Universal USBDMX
The following hardwares are NOT supported in Windows Vista or higher .
Use this link to download the legacy Lightjockey version that works with these legacy hardware.
The drivers are copied to the program folder when installing
Example:
C:\Program Files (x86)\MartinProfessional\LightJockey\HardwareDrivers
90702040 LightJockey II DMX box (taper shape)
Discontinued: 2004
This hardware is not compatible with Windows 7 and 8 (32 or 64 bit)
90702040 LightJockey II USB (original box)
Discontinued: 2002
90702060 LightJockey PCI card 512
Discontinued: 2003
90702050 LightJockey PCI card 2048
Discontinued: 2003
90702010 LightJockey , ISA (DJ) card 512
Discontinued: 2000
90702000 LightJockey , ISA (Club) card 2048
Discontinued: 2000
Same as above but with 2 DB-9 connectors
90702030 LightJockey , PCMCIA card 1024
Discontinued: 2005
90702020 LightJockey, LPT adapter card 512
Discontinued: 1999
This hardware is only compatible in Win95/98
Lj2 with win 10 work it?
Windows suddenly won't recognize my USB Interface
Light Jockey Boxes - Which ones work with M-PC
Are M-DMX and older USB DUO DMX units compatible?
How can I move from LJ to M-series software??
trouble with win10 (x64) MLJ 2.95 & USB DMX
martin light jockey
Martin USB-DMX INTERFACE HELPPPPPPPPPPPPPPP
Martin Professional Universal USB DMX with MPC V3.7XX
Universal USB interface on Windows 7/64b. not working
Light jockey 2 Windows 10 & universal USB/DMX interface
USB DMX Interface
unpinned #7
pinned #8
