For some reason my MSD stopped seeing my onekey and says trial version. Computer seems to see it still…
Did a fresh install of MSD and no change.
Need urgent help… programming a show for friday.
log upon starting codemeter service:
2017-05-30 14:50:48: Logging activated.
2017-05-30 14:50:48: CodeMeter for Windows (B5.22.1508.501.32.180)
2017-05-30 14:50:48: Running on Microsoft Windows 10 Home, 64-Bit
2017-05-30 14:50:48: Execution path: C:\Program Files (x86)\CodeMeter\Runtime\bin
2017-05-30 14:50:48: Found IPv4 address: 127.0.0.1 | 192.168.1.158
2017-05-30 14:50:48: Found IPv6 address: ::1 | fe80::3539:c3de:b9c6:98bf%9 | fe80::5d7f:1b60:b0f:6e6b%2 | fe80::b1ad:f6d2:d0a3:afd3%19 | fe80::d8fb:1406:8444:6ea9%4 | fe80::e896:693:f3be:3136%16
2017-05-30 14:50:48: Used Communication Mode: IPv6 IPv4 SharedMemory
2017-05-30 14:50:48: Used IP address: default address
2017-05-30 14:50:48: Used IP port: 22350
2017-05-30 14:50:48: Used CmWAN port: 22351
2017-05-30 14:50:48: Multicast server search: not available
2017-05-30 14:50:48: Run as network server: yes
2017-05-30 14:50:48: Run as CmWAN server: no
2017-05-30 14:50:48: Run as system service: yes
2017-05-30 14:50:48: Box Access: use direct access mode
2017-05-30 14:50:49: The list of available CmContainers has been updated!
2017-05-30 14:50:49: Detecting CmContainer with Serial Number 3-3628626 (HID)
2017-05-30 14:50:50: A new CmContainer is available (currently found 1)!
2017-05-30 14:50:50: Found new entries: 1
2017-05-30 14:50:52: Entry (100637:39808015) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_LJ.dll) with UserLimit
2017-05-30 14:50:52: API Error 200 (ENTRY NOT FOUND) occurred!
2017-05-30 14:50:52: Entry (100637:39808030) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M2PC.dll) with UserLimit
2017-05-30 14:50:52: Entry (100637:5077553) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M2GO+.dll) with UserLimit
2017-05-30 14:50:52: Entry (100637:39808029) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M2GO.dll) with UserLimit
2017-05-30 14:50:52: Entry (100637:2048) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_4UniversePack.dll) with UserLimit
2017-05-30 14:50:52: Entry (100637:39808033) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(WORKGROUP\SYSTEM,LinkManager_M6.dll) with UserLimit
2017-05-30 14:50:52: Executing Broadcast for CodeMeter License Servers
2017-05-30 14:50:52: Network server IP inquiry from client 192.168.1.158
2017-05-30 14:50:52: Network server IP inquiry from client 127.0.0.1
2017-05-30 14:50:52: Network server found with IP 192.168.1.158
2017-05-30 14:50:52: Network server found with IP 127.0.0.1
2017-05-30 14:50:52: Network server found with IP 192.168.1.235
Fixed,
The License server was on and somehow the license was taken away temporarily.
Go to Codemeter WebAdmin, Configuration Server and Disabled it.
