I have created a cue list/chase using live lights. The lights on stage change to the colours I want when creating the list/chase. When I play the list/chase it cycles through the different steps, however there is no output to the lights, and the 2d plan doesn’t indicate any colour change. Is there a setting that needs to be changed to give dmx output from running a cue list/chase?
How did you make the cuelist? Only by changing the color of the lights in the next cues? Make sure the shutter is open (if applicable) and the intensity has a level above 0% in the first cue. You can check in the cuelist values of each cue if the color changes and intensity is set a specific level.
