[Not a Bug] Timecode Cuelist - Not playing after learning GO
It seems there is a bug with Timecode Cuelist.
After learning go, we have to push go again on this timecode Cuelist to have the cuelist playing again.
Without pushing again the go button of this cuelist, the cuelist stack is not played even with timecode running (MTC)
That is intentional. It stops listening to TC after you learn the code stamps so the cuelist doesn’t jump around like crazy if e.g. audio shuffles backwards.
#3
Thanks for the explanation!
#6
It is the same logic put in place when changing the timestamp manually for a cue (or using the minus operator?). Because it is what I have seen too, changing timestamp with function - or + needs to relaunch the cuelist
#7
Thank you so much for this. I was into this issue and tired to tinker around to check if its possible but couldnt get it done. Now that i have seen the way you did it, thanks guys
with
regards
