Have you used this enttec before on ONYX?
Just verifying that all you fixture(s) are patched to Univ 1.
What does your DMX output window show?
Also, the firmware you listed is 4.1. Current firmware is 4.15. When you run pro manager does it prompt you to update firmware? If not you might download the updated firmware file and update to 4.15.
Other than that everything looks good. Get back with these answers and I’ll see what else I can assist with.
You have used this Enttec box on other laptops running MPC, but not this one running ONYX?
The patch, does confirm that you have Fix ID 1 patched to Univ 1 Addr 1. However, the Programmer Window, only shows that you are currently adjusting parameters on that fixture. I would like to see a picture of the DMX Input/Output window, that will show what’s supposed to be actually outputting. While most of the time this is what’s in your programmer, if you have “Inhibitors” or “Preview” active, this will alter that state.
Okay. I was able to plug in my Enttec and do some checking. I also have a copy of Pro-Manager 2.43. However, my setting show firmware 4.8 and it was updated through pro-manager. I couldn’t find that firmware on Enttec website - so you might need to call them and see where to get a copy of 4.8. Not sure if that will help, but that’s a start.
I updated the OS to a fresh updated Windows 10 pro no errors on installation, fresh Onyx Onyx 4.0.1010 install and no errors during installing process, still not working!
Tested with pro manager, and light Works, it means that Flow throght laptop ->usb cable -> interface -> dmx cable -> fixture, works
Solved
I went to https://www.ftdichip.com/Drivers/VCP.htm and downloaded 2.12.28 VCP drivers for Windows, and updated the usb serial converter driver, it gave me a sign saying “your installed driver is newer than you want to install”, after that it started working… somehow it worked!
