How do I rename a cuelist?
Mike,
You can rename the cuelist through the âCuelist Valuesâ window.
Once you have a view with that window, make sure you have the edit mode enabled, select the current cuelist name (ie. CL251) and type in the new desired name.
Thank you! I will try that. Your help is appreciated.
Hi, I tried this menu and it didnât work, I have however just found how to do it, in the very similarly named âCuelist Activeâ window.
Can you please explain in detail how to do the Cue renaming? Iâm bashing my head against the wall! A few months ago I was renaming cues in a very simple way that I simply can not remember any more or something changed and we were not informed.
@nid,
In the cuelist values window - make sure the edit option is enabled (red) and then click in the box to the right (to rename a cuelist) or select a cue from below (to rename the cue).
When you select a cuelist to rename, the command line will read âSET CUE CUELISTNAME @â.
For renaming a specific cue in the cuelist it will read âSET CUE 1 (or whatever the cue number location is you are renaming) CUENAME @â
