Hi, I had MPC 3.7 and I tried to upgrade to ONYX today. When installing Obsidian control systems Driver package, it failed.
It says: The installation of Obsidian control systems driver package has filed, setup will now exit.
I also checked system log and found following 2 errors:
Faulting application name: svchost.exe_CryptSvc, version: 10.0.17134.1, time stamp: 0xa38b9ab2
Faulting module name: bcryptPrimitives.dll, version: 10.0.17134.1, time stamp: 0xdf1abf1c
Exception code: 0xc0000006
Fault offset: 0x00000000000065da
Faulting process id: 0x2670
Faulting application start time: 0x01d450f7e4336e93
Faulting application path: C:\WINDOWS\system32\svchost.exe
Faulting module path: C:\WINDOWS\System32\bcryptPrimitives.dll
Report Id: 615d9d1f-b78f-4484-a4b0-646e60b4e042
Faulting package full name:
Faulting package-relative application ID:
Windows cannot access the file C:\Windows\System32\CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1304_for_KB4103727~31bf3856ad364e35~amd64~~10.0.1.8.cat for one of the following reasons: there is a problem with the network connection, the disk that the file is stored on, or the storage drivers installed on this computer; or the disk is missing. Windows closed the program Host Process for Windows Services because of this error.
Program: Host Process for Windows Services
File: C:\Windows\System32\CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1304_for_KB4103727~31bf3856ad364e35~amd64~~10.0.1.8.cat
The error value is listed in the Additional Data section.
User Action
- Open the file again. This situation might be a temporary problem that corrects itself when the program runs again.
- If the file still cannot be accessed and
- It is on the network, your network administrator should verify that there is not a problem with the network and that the server can be contacted.
- It is on a removable disk, for example, a floppy disk or CD-ROM, verify that the disk is fully inserted into the computer.
- Check and repair the file system by running CHKDSK. To run CHKDSK, click Start, click Run, type CMD, and then click OK. At the command prompt, type CHKDSK /F, and then press ENTER.
- If the problem persists, restore the file from a backup copy.
- Determine whether other files on the same disk can be opened. If not, the disk might be damaged. If it is a hard disk, contact your administrator or computer hardware vendor for further assistance.
Additional Data
Error value: C000A2A7
Disk type: 3
