Audio input using smpte port
Hello!
I have an NX Wing, can I use the xlr input SMPTE on the right for get audio from the mixer and processing to get bpm? If yes how? I don’t see any audio in
Thanks in advance
Hi @PatrizioConcioli
The SMPTE connectors on the NX Wing are for timecode only. Internally, they convert a SMPTE signal to MIDI Timecode. Therefore, you cannot send audio into these ports.
If you need to send an XLR audio signal into ONYX, I would recommend using a USB audio interface featuring XLR inputs. This USB interface will then show as a device in ONYX > Menu > I/O Settings > Settings > Audio Device. Once enabled as an input here, you can then add this input as a Beat Provider. Please see the link below for more information…
Beat Provider Input Processor
I hope this helps. Please let me know if you have any questions.
