Hi to everybody can this feature be adapted to current needs like when using capture we can have follow spots and a all fixture to the selected point? I mean this would be very usefull in a live enviorment! obviously it should be applyable to RELATIVE positioning.
Thanx
Hello Giancarlo,
To my knowledge, FOLLOW option will require integrating a 3D engine into Onyx
This is most likely already on the ToDo list
Regards,
Ofer
Thanx
Can’t wait for a built in 3D engine! I’d love if you guys had a little roadmap or something!
awesome!
Looking forward to 3D stuff!
If you are on a fixed set, you can mark several points on stage, store them in a cuelist and then create a Q-blender to be able to use a fader to move all heads on one spot simultaneously.
The fanning option will be your best friend for this.
Cheers
Not what I asked for! = )
I asked a feature like an enhanced version of that little feature, what I intendi is to be able to mark points in that window ,and then when needed use it like a top plan of the stage, so I can choose my fixtures and drag them folliwing the artist around the stage! so I can use them as follow spots .
