hello, are there any plans to let us import the hole patch from onyx to capture? or is this something capture have to do? thx.
@deflost - unless Iām miss understanding, this is already possible. When you have Capture running and ONYX on the same network (or machine) make sure you have CITP enabled. And on the proper NIC cards. You should see a message in ONYX showing connectivity. Then in Capture there should also be a spot to select the console (ONYX). From there you should be able to import either direction. A dialog box should appear asking what you want to do. Use this link to read about CITP and the additional links in the manual to go through it all.
