linking attribute
working with 4.8.12440
I have ADJ Focus Profile and ADJ Hydro Profile
when I select them both the intensity , Pan Tilt, Color (cym) they work together
when I select the Framing, and or the animation wheel they do not work together I need to select only Focus or only Hydro to make the framing and or animation wheel to work
I can see this happing with the gobo wheel base they have different gobo but still the same number of gobo and both have animation wheel.
does not make any since on the Framing side they both have the same number of channels and control they should act like the Intinsity, Pan Tilt, or Color (CMY)
I have also notice the gobo images are not correct and will send a Library request to get that fixed
any body want to coment on this
