Live Color Change FX Possible?
Hey,
Is there a way to create a live color change FX like on Chamsys with soft palettes? I want to select two colors (start and end), and then it should fade or blink between them, ideally with a speed fader or even a “Tap Speed” function.
Another scenario: I want to set up the console so that someone with no lighting experience can just press buttons and trigger pre-programmed looks. The idea is that I pre-program a few fixed colors for MHs, pars, and bars, along with positions, movement FX, beam FX, and intensity FX. There would be five faders for intensity control of all fixtures, plus faders for the hazer, movement FX speed, strobe, and blinder. The person operating should also be able to create a color fade or blink effect on their own, with the simple tap of 2 colors and one fader he has to push up.
Is this possible?
I hope you understand my messy explanation and my problem.
Thank you in advance!
