I’m attempting to connect my Asus tablet running Onyx to my M1 but im having no luck. Both the M1 and Onyx on the tablet are running version 4.2.1057. I have a router connected to the remote network port on the M1 and the tablet is also connected to that router. I pinged the M1 through the cmd on the tablet and it came back with a response but it seems the software isn’t communicating. Any tips would be much appreciated.
Did you make sure to enable X-Net (for joining shows) communication on both machines. Under the Network settings you should see the networks as well as any devices and shows on the network. Sorry I can’t remember the exact menu path at the moment. Also check the IP’s. Make sure they are both in the same range.
Here’s a link to the manual for further assistance.
https://support.obsidiancontrol.com/Content/Networking/X-Net.htm
