Hi guys, I haven’t had time to confirm this in a test show file 'cause I’ve got to get the current show finished. But what I’m experiencing in Onyx 4.2.1057 looks like this:
Create a chase cuelist “My chase” set to 154bpm. In Playback Buttons, “Go” runs the chase all ok.
Release “My Chase”, all ok.
In a separate Timecode cuelist (I’m running internal timecode) set a macro on a cue to “Trigger”, “My Chase”, “Cue 1”
Observe that when running the timecode cuelist, “My Chase” is activated and Cue 1 of the chase is live, however the chase is NOT running and I can’t find any way to make it run from a separate cuelist.
[I also notice that “My Chase” is being automatically released on the next cue in the timecode cuelist, when there is no cue set to release “My Chase”. EDIT: I haven’t been able to replicate this in a test showfile]
Mmmm weird, hope it’s not a corruption in the showfile or the next few days are going to be hell!!
I’ve revisited this with a new blank default showfile and can confirm and replicate this bug (Onyx ver 4.2.1057).
A chase will NOT run when triggered by a macro from another cue list (though the chase button in Playback Buttons displays the play icon correctly). None of the following attempted workarounds work:
Multiple macro TRIGGER commands
Macro PAUSE commands
Setting the chase to be the MAIN cuelist
A macro trigger of a chase fails from both timecode and standard cuelists
Trigger any chase cue
Clicking GO directly on the chase playback button causes the chase to run correctly as expected,
Obsidian people can you replicate this issue also?
The macro was triggered with the cue 1 target specified. This intentionally does a GOTO CUE 1 and stops the chase. Trigger it without the Cue #and it runs as expected.
