Is there a way to ignore an override on a particular cuelist?
I have a FX speed override for my pan/tilt parameters that I use to control my ballyhoo effect speed while busking. The problem is it ruins my beam fall effect because it causes the tilt speed to get out of sync with the intensity.
I tried raising the priority of the cuelist that is my beam fall effect so it is higher than the priority of the speed override but the override is still controlling the speed of the beam fall playback.
Any suggestions/working around
