I was curious to see if there was the ability to make your own mlb files. I’ld like to start organizing so of the prop files i’ve collected.
Also I’m
Also I’m
.mlb (Model Library) files can be create din the Modelr module
You can create your own files, and import objects from the library, into your own .mlb file
BTW, any scene (.scn) is technically a library too.
In the Modeler you cna do Open and then change the extension from .MLB to . and select a .SCN file.
You will have access to all objects imported into that scene.
