We have some chinese Robe Pointe clones that we’ve had good use out of with the real Robe Pointe fixture profile in M-PC, however we’ve had to adjust the default preset for them because the home position for pan is off by 90° degrees. How do I also adjust the default position of the fixtures in show designer such that they behave like the cloned versions do?
If you send us (support@lighthouse.nl) an e-mail with some information then we will create a new profile for the fixture.
Please include the name of the manufacturer, the name of the fixture model and in what direction the pan needs to be offset ( Clockwise/Counterclockwise when the fixture is hanging/standing ).
Simply rotate the fixtures by 90°, on their Y axis…
Oh phew. Thanks for the heads up! I had a feeling it would just involve rotating the fixture. I just had to make sure there wasn’t already an easier way to just change the default pan instead if move every fixture.
This is not necessary at all…
Simply select all required fixtures, and rotate at once, via Orientation sidebar option…
