Is there a way to smooth moving head’s pan/tilt movements between cues? Right now, if I program a cue to have the heads at position a then next cue position b, it’s a hard start and stop which depending on the fade time can make the movement look jolty. Is there a way to put something like an s-curve on movement?
The Cue has a fade curve column with the exact curve you ask for.
Yeah, so, I’m an idiot
Thanks!
