Anyone know how to completely delete a show file frrom Onyx (MPC)???
Use your windows explorer. Look under User/Documents/Obsidian/Onyx.
Nothing there that would resemble a show file. I looked all over related folders: Users, Documents, Obsidian Control, Onyx - nothing. Any other ideas? What is the file extension for a show file? Is it the same name as the show? My show is MAK1. Would that be the name of the show file?
Show files now have the extension “.onyxshow”. So your show file would be MAK1.OnyxShow. Have you done a “save show” and see what the directory path is? Did you happen to change the location of where you saved the show?
Here’s a screen shot of what it should look like.
Thank you very much! Greatly appreciated!!!
hey Thank you so much for this. I was into this issue and tired to tinker around to check if its possible but couldnt get it done. Now that i have seen the way you did it, thanks guys
with
regards
