Install Error 27503
I tryed to install Onyx on my Home-PC
And i got an error while installing:
Error 27503. Error retrieving version string from Microsoft SQL Server ‘(localdb)’.\ObsidianOnyx’. Class not registered (-2147221164)
Any ideas how i could solve this issue?
Sincerely
  • Sascha
I found when the problem occurs. I had same issue when i had installed any othe than 2012 SQLServer LocalDB. I had installed SQLServer Express 2017 with localdb support then i uninstalled LogalDB then I be able to install onyx.
I think this is the onyx bug.
I you have installed Onyx and then you install SQLServer LocalDB component you will not be able to load show.
I hope guys will fix the issue quickly because I’ve another software on my laptop which needs to have another version LocalDB
Very late response, but sadly that doesnt help me since, even when i uninstall every SQL component, its still not installing
