Kinetic Ball -
Hi there I have a show coming up that I need to Per-Vis 300 kinetic balls. Can Msd6 do this ?
I would need to be able to see the balls go up/down also be able to map all the balls so I can see the video content that will be going over them.
Cheers
Ant
hi, if you have MSD Pro you can create dynamic objects. create a layout of hoist bases, and attach fixture/screen to hooks. bases are addressable
page 109 and on will shed some light on what it takes to build
http://www.lighthouse.nl/downloads/_MSD5/MSD%20User%20Manual.pdf
#3
Yes, it can be done
As mentioned by @Sylas, use motors, via Dynamic Object, to lift the balls
You can also set the balls, as a Media Feed element, so you can map video content to them
