Onyx won't open - Object reference not set to an instance of an object
Had trouble with the installation with error 1720, got that resolved with the registry fix and Onyx completed the installation. Now when I try to open the program, I get this error.
Windows 10 running in Bootcamp, 2018 Macbook Pro.
Sounds like something a .NET program would say if it had an issue… Do you have the latest .NET distribution installed?
#3
I saw another person post the same issue after I had made my post. I did a restart and it worked. I’m not sure about the latest .Net.
#4
Hi there
I received this message also: Internal Error Object reference not set to an instance of an object
I have had the same problem, the first couple of times after restarting the system it worked fine, however this time I can not get past “Internal Error Object reference not set to an instance of an object”
Has anyone found out what causes the problem, and what is the best way to fix it…?
Many thanks
Mark
