OSC Documentation
Hi there,
I was wondering if there was any documentation for the OSC addresses used by Onyx. I am able to control the “known” addresses but I am wondering if I can control the extra 10 playbacks that are to the right of the main playbacks over OSC as well. Can’t find it in the TouchOSC editor. I’m also wondering if I can control the faders that are present on the M-Play. Again, it would be nice to have a full documentation of how OSC can be used inside Onyx.
Thanks for the help!
This is the OSC documentation about the M-Series software. I guess a lot must be the same :wink:
OSC
All OSC addresses start with ‘Mx’.
There are 7 categories:
- LED buttons
- LCD buttons
- faders
- belts
- scroll wheels
- playback
- configuration
LED/LCD buttons, faders, belts and scroll wheels have an identifier in their path.
This identifier is mapped to a real physical control element on the desk.
The console layout with the identifiers can be found in the iPad and iPhone Martin-Mx-series_V1.10.touchosc file.
You can edit this file with the TouchOSC Editor from Hexler.
iPad and iPhone touchOSC layout (under M-series -> OSC remote access):
http://www.martin.com/controllersupport/
TouchOSC Editor:
http://www.hexler.net/software/touchosc
LED Button
/Mx/button/
/Mx/button//led
buttonId: required identifier
led: indicates the led status (optional)
example: /Mx/button/5511
/Mx/button/5511/led
/Mx/button/4201
Button action (OSC client to console)
Path:/Mx/button/
Value: 0 (up), 1 (down)
LedState (console to OSC client)
Path:/Mx/button//led
Value: 0 (off), 1 (on)
LedColor (console to OSC client)
Path:/Mx/button//led/color
Value: blue (on, off), red (blink)
LCD Button
/Mx/button/
example: /Mx/button/6101
/Mx/button/6102
Path:/Mx/button/
BackgroundColor (console to OSC client)
Path:/Mx/button//color
Value: green, red, blue, orange, gray, blue, purple, yellow
Text (console to OSC client)
Path:/Mx/button//text/
Value: string that represents the name
TextColor (console to OSC client)
Path:/Mx/button//text/color
Fader
/Mx/fader/
faderId: required identifier
example: /Mx/fader/4203
/Mx/fader/2202
Value (both directions)
Path:/Mx/fader/
Value: integer (0 - 255)
Belt
/Mx/belt/
/Mx/belt//channelValue
/Mx/belt//channelName
beltId: required identifier
example: /Mx/belt/6112
/Mx/belt/6112/channelValue
/Mx/belt/6112/channelName
Value (OSC client to console)
Path:/Mx/belt/
Value: integer (> 0: up, <= 0: down)
Name (console to OSC client)
Path:/Mx/belt//channelName
Text Value (console to OSC client)
Path:/Mx/belt//channelValue
Value: string that represents the value (DMX or percentage)
ProgrammerMode (console to OSC client)
Path:/Mx/belt//color
Value: gray (none), orange (inactive), red (active)
EffectMode (console to OSC client)
Path:/Mx/belt//channelValue/color
Value: gray (none), orange (inactive/active)
Linking (console to OSC client)
Path:/Mx/belt//channelName/color
Value: gray (off), yellow (on)
Scroll wheel
/Mx/scroll//
wheelId: required identifier
direction: up, down, left, right
example: /Mx/scroll/4110/up
/Mx/scroll/4110/down
Path:/Mx/scroll//
Playback actions
/Mx/playback/page//
action: go, pause, release, select
example: /Mx/playback/page1/1/go
/Mx/playback/page5/20/pause
/Mx/playback/page9/3/release
NOTE: No playback feedback information is send from the console to the OSC client.
This will be added at a later moment.
Configuration
Current devicespace (console to OSC client)
Path:/Mx/configuration/deviceSpace
Value: devicespace
Devicespace down (OSC client to console)
Path:/Mx/configuration/deviceSpace/down
Devicespace up (OSC client to console)
Path:/Mx/configuration/deviceSpace/up
Refresh all console elements (OSC client to console)
Path:/Mx/configuration/deviceSpace/refresh
