Hello. I recently updated my Onyx program from the .1010 to the 4.2.1045 and discovered that there is a problem with the Submaster Module. The green/red/yellow lights that indicate whether or not the cuelist is active/in transition/selected does not light up at all. I go and press my cue for my front wash and the light physical lights themselves turn on, but my module doesn’t show that they are even being pressed.
is this the actual MaxModule or are you referring to the section of an M1 or M6?
It is all run within Onyx. No external/physical console.
Please post a screen shot.
Were you able to discover the issue?
Yes it has been fixed for the next release. Thanks for sharing.
