Thanks Gian-carlo! The reload workaround works perfectly!
Is anybody having issue with the maximize zoom feature of the 2d plan?
When hitting this function, the 2d plan is not automatically zoomed in, it stays with a far away zoom level.
I have an issue with a full new show (no cuelist, default preset not changed) and result in 2D plan.
Patch following fixture:
Add a Dylos zone around the bar, and play the media 35 from folder 3 Monochrome:
As result, the 1st, 3rd and 4th bar are correctly doing a full black and white chase, while the 2nd bar as its 6th pixel (top to bottom) which is Magenta:
This also happen with fixed picture (like Elation Gobo). Instead to output RGBW at 100% on this pixel, we have all at 100% except the green (which explains this light magenta):
As workaround, I have moved the LED Bar in the 2D Plan, and it has fixed this pixel trouble
