Could I request the ability to rename a cuelist after one has been saved? Some of our tech volunteers (we’re a small church) don’t understand what CaSe SeNsItIvItY is, and it would be lovely to not have to rebuild the entire cuelist just to fix a label.
You can select the cuelist in the Playback Buttons pages or from the Main Playbacks row at the bottom of the screen with the faders. Then, as was said, enable edit in the Cuelist Values window by clicking on Edit Mode.
Thanks so much. Yeah I’ve tried the rename function (assigned to an f-key) and then tapping on a playback button or cuelist, and neither seems to do anything. I’m a little confused by this.
