You may find you need to send two different protocols to ONYX: for example, you will need to send your trigger/timecode protocol in order to change which lighting state is active on ONYX, whilst simultaneously sending Ableton Link, to synchronise the current lighting effect with the current tempo. Ableton Link is not intended to trigger lighting states, but instead intended to set the tempo of DyLOS & chases.
