I have regular cues for changing the colors of my fixtures. Currently they only contain color data (In form of presets) I recently added three RGB Lasers to my lighting rig. The problem is my lasers (Scorpion Dual RGB) don’t have Intensity. They are activated (Basically Intensity Full) the second you pick a color. In my Colors Parameters I have none, Muti, Red, Green, blue, etc. The only parameters I have for intensity are Strobe and the slowest setting is not off.
If I add the lasers to my color cues they automatically turn on with the color even if I don’t have the lasers selected via cues or presets. Before adding the lasers everything worked great, whatever fixtures I was using I could just press the color cue and everything would change only for the fixtures that have Intensity. Currently I have to have cues for each of the colors only for the Scorpion lasers and if I have the lasers in a lighting scene I have to press two color cues (The main one that controls all my other fixtures, and the one for the Scorpions.
Is there anyway to add the Lasers to my main color cues so they are only activated when I have a cue turned on for them?
