Please tell me how to properly configure DMX input on art-net from another device? Onyx does not see the incoming signal
whats the IP address of the PC?
I understand that one is at the entrance and one is at the exit? Or should there be one IP? I have 10.0.0.1 on the input and Nov 2.0.0.1 on the output I do not quite understand the routing in Onyx itself
I dont think you can read in 10.0. Use the same 2.x in and use different universe numbers.
I have two network adapters with two IPs, respectively, but how do I configure one to enter and the other to exit?
I have tried to do that before and what I have found is it was not possible. I could be wrong tho.
I am guessing you are trying to achieve this on a PC then?
One work around could be use 2 PC’s, put them in a slave setup and use one as your input and the 2nd one as your output. I haven’t tried that myself. If I get chance I could give it a go out of interest.
Are you trying to merge 2 Artnet streams?
Cheers
Steve
Yes. I want to manage playbacks in onyx by an external device in a single art net flow
You don’t configure in and out to the specific artnet IP. Send a Universe on a free number (e.g. 20)
Map the Universe as a Port. Assign the port to a function in the DMX Input.
Some consoles send artnet with an offset. You will need to know that (Artnet Universe 20 could be 20 or 19)
There is a DMX I/O Window that allows you to see the current Universes
Mapping is explained here:
https://support.obsidiancontrol.com/Content/Advanced_Controls/DMX_Input.htm
You may need to use an external test tool on a laptop in your network to ensure you are actually seeing Artnet from the other device and at what Universe, like Artisit License DMX Workshop or Artnetominator.
