I had a perfectly working Artnet setup on Onyx 4.4 using a DMXking eDMX4 Pro patched to firmware 3.10. I upgraded to Onyx 4.6 and everything worked fine at first… until Onyx keeps losing connection with my ArtNet device every minute or so and it stays disconnected for a minute or so. I’ve played with just about every combination of settings in Onyx EtherDMX and cannot resolve it. On 4.4, I had the most stable experience with manually inputing my ArtNet device’s IP address in the “faking Unicast” section. Any suggestions on how to troubleshoot this further or even better a suggestion on how to fix?
I’ve tried this on both Windows 10 x64 and Windows 11 x64 with the same result.
I’m running Build 4.6.1220.0 with an M-Play (NOVA license).
I have both ArtNet and sACN Sync disabled. I attached my full EtherDMX Device and EtherDMX configuration.
Hello. There are indeed problems with art sales in versions 4.6.The connection is lost.The latest version 4.6.1220 is installed.after 2-3 hours of work on art NET, problems arise steadily.The connection is completely lost or part of the channels in 1 and 5 universal is partially blocked. I have to switch to physical ports (I have an M2PC wing with 4 DMX OUTPUT) This is unacceptable !!!I hope everything will be fixed as soon as possible
