Although not a change in the software, probably also worth mentioning this build includes a fixture type library to which a fix had been applied earlier on that affects mostly strobe-style fixtures (not having their intensity open linearly from the start of the DMX value range, but rather keeping intensity at zero for the first few DMX values): such fixtures didn’t respond to command line intensity setting, highlight, inhibitive controls (including GM) and their default values were often wrong.
Recent fixture type libraries already included this fix.
Not sure if it is user error but sometimes I can’t get output from Dylos. It’s been an intermittent issue. Last time it happened I noticed that setting the fixture Intensity Paremeter in the programmer, e.g. at full, fixed this. (Needless to say, I’ve had intensity levels in another running cuelist. )
Running 4.6.1221 on an NX4 and a Surface Pro, and am also experiencing many issues with networked shows. Many disconnects, partial show loads, and synchronization issues. X-Net is not running suitably for a live environment in this build.
So I have had this happen twice on 4.6.1221. I have a networked show that I connect to remotely and it looks like everything is going fine till I try to save a new Group preset from the secondary position at which point the software becomes extremely sluggish and unresponsive on the secondary position (except 2D display continues to work ok) and eventually the secondary position disconnects completely from the main/primary and the title bar then switches from Secondary to Primary
On one occasion it did finally catch up and began operating normally again but there seems to be some kind of issue storing Group Presets from the Secondary console when networked.
I have about 600 tri-RBG pixels on LED strips, I was saving a Group of those pixels with every 5th pixel selected so I could select the group and then next/prev every 5th pixel.
Want me to PM the show file?
I also had the same issue saving a new Group from the Secondary console when doing those same 600 pixels and did a 300 pixel mirror so I had alternating blocks of 2 pixels
Hi, i have a problem, i began to create a show with v4.6.1221 in my computer i forgot that NX2 its in 4.6.1220, now i can´t use work with join sesion. is there any way to solve it? or i have to begin in v4.6.1220
Hi, in V4.6.1221 in 2d view i fond this issue, in fixture FOSH Halo Led the combined fixture works fine but if a take the external pixel alone as u can see in 2d view don´t work, if i repeat the same with clay paky k20 it works fine ¿its possible the problem is in fixture library?
Another question in RGBW - RGBWA fixture Is there any way that if I select a white or amber color onyx uses the W and AMB channels or I always have to use the attributes control manually?
Thanks, and about this “Another question in RGBW - RGBWA fixture Is there any way that if I select a white or amber color onyx uses the W and AMB channels or I always have to use the attributes control manually?”
