Good evening,
Today I tried again to connect via Artnet my Hp laptop to a Pix1 AtomicPro control unit for ledbar. Unfortunately my pc doesn’t have ethernet port so I have to use an usb hub, and that has another ip address. I disabled the firewall and set the ipv4 first in automatic, then in manual, also for the pixbar control unit. Obviously I also set the parameters in onyx but from software I can see on devices only the ip of the hub but no the pixbar control unit, so I couldn’t see any output.
I have beta version 4.9.1257, someone could help me?
what IP addresses are on the PC and the fixture controller? A lot of devices do not show up inside ONYX as that communication is not added by those, but they will receive Art-Net.
I cant find any user manual for the controller.
I tried many things, the last was: ipv4 automatic; on Onyx ethernet automatic; artnet rules in-out; range output correct; broadcast on; and on override options the ip of the pixbar control unit (in my case 200.000.000.100) and the universe range correct.
I uploaded one page of the manual because a can’t put more that one.
I copied the same I saw on the control unit, so that and Onyx ip corrisponded. Next time I’ll try to put this other one. Thank you so much for the support Matthias
I solved the issue by ONYX reboot. I didn’t think before. Thanks so much anyway to everybody for the help.
