DAX Error - Sharedmem DMX universes origin unknown.
- InternalTimer origin CuelistUI.
Afterwards trying to load a new show it got stuck in “Loading and optimizing show data…” (waited at least 1hour)
Tried to uninstall former version and have the same issue.
Assuming you have the same problem as Raul, could you try:
uninstall the beta
install the latest release (1057, for example)
uninstall the release
install the beta
On Raul’s system, an older version wasn’t uninstalled properly. Not sure whether the above will fix it, as the traces I found on Raul’s system that mixed everything up were prior to the Onyx rebranding while the latest release should have overwritten those. So, if the above doesn’t help, I may need another TeamViewer session to determine which old version may need to be installed and uninstalled again.
Best guess is in your Downloads folder. Haven’t found installers for that specific version range here as it dates from the transition time between Martin and Elation and must have dropped off somehow while moving over.
Alternatively, you could give me access to your system using TeamViewer or something similar, and I’ll clean your system manually. Just PM me the ID and password if you’re ok with that.
Thank You Matthias!
Sorry for late response… Satellite Broadband doesn’t have large Gigabyte allowance.
Will try again when have a computer free.
Thank You also Gert and also sorry for the late response as above. =/
gave up on old laptop, doubtless there is something remaining from M-pc on it but it isn’t going to e used any more for lighting. Fresh install on new i5 system working well and stable: confident to use under gig conditions!
