Bug RDM 10 V3.0.0 RDM-Discovery via XLR triggers Network connected RDM10s
i have 2 RDM10 Connected via Ethernet
First RDM10 is set to Artnet universe1
Second RDM10 is set to Splitter AB
On the Second RDM10 i connect a Console which is doing RDM.
On RDMDiscovery from the Console, the First RDM10 connected via Ethernet tu the Second RDM10, the First RDM10 has Flashing white LEDs simiular to the Second RDM10.
Hi @Q-Light
Apologies for the delayed response.
If you do not want the second RDM10 to convert the incoming universe of DMX to Art-Net, connect to the RDM10’s DMX Inputs webpage, and ensure the “Input Source” is set to “DMX”, with the “Protocol” set to “None”.
I already suspected that it was meant to tunnel RDM over the network, so I tested that as well, but it didn’t work.
Thank you for sending me a DM. I will reply to this shortly.
