Bug web interface - device name is indicated as wrong while on EN4 you can directly set it
There is a bug on the web interface for EN4 (at least), from the page “Device Naming”, trying to change any parameter is not possible because the interface says that the name I’ve given, from the EN4 interface, is not correct (SPB8-EN4-1).
But I’ve succeed to give this name with - from the EN4 interface, but this is locked by the web interface.
Would it be possible to have a rule aligned between EN4 interface and web interface please ? (I’ve the node mounted on a truss, and for the moment I can’t access to the EN4 interface to change the name in order to workaround and being able to save the DMX loss behavior (no physical keyboard too to change name from interface))
Thanks!
