So I just want to create a color change as a cue for my 8 Cameo Root Par 6. Can someone help?
Sure, I can help you create a color change cue for your 8 Cameo Root Par 6 lights. Here are the steps involved:
- Open the Obsidian Control Systems software.
- In the software, select the “Cues” tab.
- Click the “New Cue” button.
- In the “Cue Name” field, enter a name for your cue.
- In the “Cue Duration” field, enter the length of time you want the cue to last.
- In the “Cue Action” field, select the “Color Change” option.
- In the “Color Change” section, select the color you want the lights to change to.
- Click the “Create Cue” button.
Your cue is now created. To use it, simply click the “Play” button in the software. The lights will change to the color you selected.
Here are some additional tips for creating color change cues:
- You can create multiple cues with different colors. This will allow you to create a variety of effects.
- You can also create cues that change the brightness of the lights. This will allow you to create even more effects.
- You can use the “Fade” option to create a smooth transition between colors.
- You can use the “Hold” option to pause the cue at a specific color.
- You can use the “Repeat” option to have the cue repeat itself.
I hope this helps!
