Hey, I am working on a school concert, and I am using 4 stealth craze movers with several others, and I had previously programmed my cues just setting the light to 100% bightness, but when I actually connected the lights, they use 4 different channels to control the lights. My question is can i bind those other channels to the brightness of the stealth craze, or will i have to edit every cue? Thanks!
Could explain better. Because the translator didn’t help me much
Yes, You can just merge new setting to a existing intensity cue.
For example take 4 movers, don’t touch any other attributes, or presets, just set them @100% intensity.
Record > Playback 1 (can be a submaster.
Then clear clear.
Select another device, set only the intensity @100%.
Record > same playback.
On the popup window click MERGE.
This way all 5 fixtures intensity will be controlled with the same fader.
