Can I set DMX Hold on each output of EN12-45?
Can I set the DMX Hold on individual outputs of the EN12-45 Node? I want outputs 1-11 to stay on “Forever” and I want output 12 to stop sending DMX when I power off my console.
Hi @BrandonHart
Welcome to the forum.
On the EN12-45, the DMX Signal Loss setting applies to all 12 ports. It is not possible to set a different signal loss setting per port.
To achieve this, you would need a separate Netron device, such as an EP1, with DMX Signal Loss set to Disable DMX.
Its a good suggestion and has come up from others to power off e.g. some relays but leave some outputs on the last look for e.g. an LED room light system.
I’ll add it to the feature request list.
