Can you add a rotation tool to the plot it could be very usefull sometimes for selection of some trusses that are not straight etc…
Thanx!
Hey Giancarlo,
That is a nice idea. As a work around and maybe just as fast, couldn’t you use the path or lasso selection tool?
Just a thought,
More options we have the Better It Is,but lasso
sometimes with mouse or trackball Is not so helpful .
Rotating an object turns it around a fixed point that you designate. The default reference point is the object’s center point. If you have multiple objects in a selection, the objects will rotate around a single reference point, which is the center point of the selection or bounding box by default.
