Can you make the F-keys flash?
Is it possible to make the F keys act like a flash button? I would like to add a blackout and a fixture group 100% intensity button. Currently just assigning a preset to them, but then I have to have another preset to turn them off. Ideally I would like to just hold the F key for the desired function, then it turns off once I let it go. Exactly like how the flash button works on override cues. (My workspace is already at 20 faders, so I am trying not to spill over to a third bank)
Is there a solution to this? I also have this problem.
Hi @adamportelli
Welcome to the forum.
It is not possible to assign Cuelists to F-keys. Therefore, F-keys can only be used to trigger items. They could not be configured as a flash key.
If you can let me know what ONYX hardware you are using, I can see if there are any alternatives.
In ONYX 4.34 software that is currently in development, it will be possible to assign different cuelists to the buttons above and below playback faders, greatly increasing the number of different cuelists that can be accessed on a single playback bank.
Good to know, thanks. I’m running 4.32.1314.0 onPC with a NXP wing. Yeah it would be a really useful function, Hog has had that capability for years :slight_smile:
I am assuming that the 10 playback faders and playback buttons 11 thru 20 are already populated on your bank. I am assuming you wanted to add other flash keys to the F-keys, so you could toggle the Multi-Function Keys between F-keys and Playbacks mode, without needing to change bank. As flash buttons cannot be placed on F-keys, you will need to change banks for the time-being, until ONYX 4.34 is released.
