Hi All,
I’m facing an issue with multiple Capture show i created.
I can correctly list in CITP all the fixture and make my import ready, but when i try to import all or import selected, the import process stop working.
Nothing is imported, only two plan page is added “Capture : Top” and “Capture : Front”.
After starting looking at the logfile, i found this issue, who look to be related with this issue.
|00004667| 00:00:37.1450366|[21204] ##FixtureLogic##C#16520#MxCommand::StartDatabaseTransaction:return||
|00004668| 00:00:37.1450366|[21204] ##FixtureLogic##C#16520#MxCommand::StartUndoLog:entry||
|00004669| 00:00:37.1450366|[21204] ##FixtureLogic##C#16520#CommandUndoData::StartUndoLog:entry||
|00004670| 00:00:37.1460342|[21204] ##Common##X#16520#StoredProcedure::Execute: Error||
|00004671| 00:00:37.1460342|[21204] Code = 80040e14||
|00004672| 00:00:37.1460342|[21204] Code meaning = IDispatch error #3092||
|00004673| 00:00:37.1460342|[21204] Source = Microsoft SQL Server Native Client 11.0||
|00004674| 00:00:37.1460342|[21204] Description = Could not find stored procedure 'WorkSpace.dbo.spUndo_StartCommand'.||
|00004675| 00:00:37.1460342|[21204] ##FixtureLogic##C#16520#EventDataQueue::RegisterEventData:entry||
|00004676| 00:00:37.1460342|[21204] ##FixtureLogic##C#16520#EventDataQueue::RegisterEventData:return||
I presume it’s more a bug than an issue with my show or configuration, this is why i posted here.
Do not hesitate to contact me if you need my source files.
Best,
Yannis
